In Reply To:
I don't think the L is really a truly comparable bike to a 56.
There's a lot less bike on a L than a 56. I brought that up with Mark in a previous thread. Not sure how that factors in, but it's something to consider. I think the XL and 56 are much more comparable. I.e., that's the size I'd ride in each. The L would be much too small (need like a 13cm stem on the L vs. a 10cm stem on the 56 P3C to achieve the same position).
Reach-wise, yes, but not stack-wise. The L Transition actually has ~1cm greater stack than the 56 P3C (which accounts for ~0.3cm of the shorter reach.)
Besides, the XL was changed for 2010 and now has a 2cm higher stack, as opposed to the previous years where the stacks on the L and XL sizes only differed by 1mm.
I also find it sort of interesting that you'd ride those 2 sizes...since, IIRC, I'm at least 3" shorter than you, and a 56 P3C is what I had borrowed for the "Something Borrowed..." testing (and fit great) and I'm thinking about getting a L Transition. Of course, the fact that I'm now running a Scott 100K bar probably has some influence on that (i.e. it requires a shorter stem for a given pad position than the Vision bars I had used on the P3C).
In any case, you lost the point I was trying to make, which wasn't how the P3C compared to the Transition, but how the P3C compared (by inference) to the Shiv...and how that didn't match Gary's summary above.
