needmoreair wrote:
You (and DD) are the ones saying everything adds to base.
I give you a specific example of work not adding to base (peak) and you take that example and run off on a tangent about how to make someone peak?
You can take an athlete and do that and have a moderate build progression that never sees them having to significantly overreach/overcompensate. I specifically said that in a previous post.
You cannot, however, take an athlete and plan to peak them, overreach them, decide "hey, I'll just keep building them instead of tapering to allow for fitness gains", and then keep expecting them to improve.
None of the above has anything to do with the point I raised, however: that being that once an athlete has been brought to a peak, that you can simply add to that fitness.
The argument you're trying to make keep shifting and hasn't been well articulated from the start. So you'll have to forgive me (and every other person on this forum) for not being able to understand what the point of your argument is.
I'll respond with a few succinct points -
1. Intensity does not erode aerobic fitness, though a shift away from volume to exclusively high intensity training will. That's the result of lack of volume. Not some kind of bizarre physiological adaptation where training makes you less fit.
2. If you do not taper/peak an athlete, you could continue to build on that fitness indefinitely - as long as you're varying the stimulus (intensity, duration).
3. L1/L2 exclusive training in base/build/peak friel-esque models is bs. That's DD's point. A marathon runner is going to be doing v02 work early in the season and subthreshold work as the race approaches. A 1500/5k runner will be doing the opposite. General to specific. Those Kenyans that threw down at the major marathon's this fall? They're not going back and running all easy miles now. There's a recovery period then they're back to working on the systems that were neglected during the marathon build - hills, v02, leg speed, etc, etc - not just easy running.
___________________
Twitter | Kancman | Blog
