BigHammer wrote:
I have the Ultergra brake/shifters (ST6871) which come with etube wires attached. This makes it a challenge to work out where to use the y-cable (EW-JC130-SM).
Did you use some sort of mini-junction to join the y-cable with the cables already attached to the brake-shifters? Or is there another obvious solution which I should have noticed?
I am not familiar with the ST6871 shifters and the cable type attached. It depends on the type of plug (male or female) at the end of the shifter cables. Is the plug type on those cables the same type of plug as on all the other components, like the junctions, batteries, derailleurs, etc. If so, then a standard cable will attach (such as the Y-Cable). On the other hand, are the cables intended to plug directly into a Junction box?
If they are the former (same as all other components), then you could plug the Y-cable directly into those ST6871 cables. However, if they are the same type of plug as on a standard cable and intended to plug into a junction box, then you cannot use a Y-cable without junctions, such as the 2-port EW-JC200. If the cables are long enough to reach the junction, then it probably does not make sense to try to use a Y-cable.
