bluesmachine wrote:
DatoMakin:
I have a question about your aerobar set up with the dagger stem you ordered from the Felt website. How much lower were you able to get up front?
I currently have my pads right against the Felt basebar and the extensions mounted below the basebar but still, I would like to get lower in the front to improve my overall postion.
With you having the dagger stem in hand and on your bike, in your opinion would it allow one to get lower in the front?
Thanks in advance.
I never used the normal set-up since I wanted to keep my Pro Missile aerobars. However, I'm almost sure you will be able to get lower with the dagger stem adapter. Also because you could get a very low stack aerobar to pair with it. It will never be a very big difference though. I could snap a picture of the stock stem angle next to the dagger stem adapter tonight if you want. The stem adapter is -16 degrees by the way...
