So if you're running an ilink type cable with full liner, why do you need an inset cable stop? Couldn't you just drill a hole in the frame just big enough for the cable liner to pass through, and use the top tube itself as the cable stop? The i-link would press against the top tube. This is shifter cable, not brake, so there wouldnt be tremendous amount of force.
Minimal hole drilled...?
I just got a P3c so considering the mod.
Want: 58cm Cervelo Soloist. PM me if you have one to sell
Vintage Cervelo: A Resource
