lordhong wrote:
My road bike has a 105 compact 10sp crankset on BSA BB.
If I was to get a Classic+Gossamer set and replace the 105 crank, I don't need to get a new BB, right?
I originally put my Gossamer crank into a Dura-Ace BSA BB, and the fit was tight... very tight. Once installed, the crank spun very smoothly like you would expect from Shimano. When I wanted to remove the crank to move to another bike, I needed a rubber mallet and some strong whacks to remove the crank.
I do not recommend this. I since purchased an FSA MegaEXO BB, which has worked just fine.
I read somewhere on this forum, I think it was from Damon, that although FSA MegaEXO, Shimano Hollowtech II, and Rotor BB are all 24mm spindles, FSA is
plus a tiny manufacturing tolerance, and Shimano/Rotor/Chris King are
minus a tolerance. Basically, keep FSA crank with FSA BB, but the others will play a little bit nicer with one another.
Alex Arman
Strava
