Quote:
Is there any science that explains why aerobic workouts lower anaerobic capacity
Depends on what you mean by aerobic workouts. Some of the best workouts, sprints, will increase aerobic capacity the most. So is this an aerobic workout? They also will increase anaerobic capacity. So both are increasing. But the problem is that too many sprints breaks down too much so a small amount of high intensity workouts increase aerobic capacity, too much will actually lower it.
Low level workouts also increase aerobic capacity and speed regeneration but they also tend to reduce anaerobic capacity.
Some of this may be based on stressing different types of muscle fibers.
This is from Olbrecht who has supervised the training of over a thousand athletes over the last 25 years, most for an extended period time. Everyone gets tested and everyone keeps track of their workouts. Take it for what it is worth. He discusses the effect of different types of workouts in his book.
He believes too much intensity even when it is below threshold can be too stressful and have negative effects on aerobic capacity.
That is why it is best to experiment and closely monitor your training and evaluate with some type of reliable testing.
Remember, there is never enough aerobic capacity so this should be the main objective of all training programs but in the short term, the threshold will respond to training of the anaerobic system. Most endurance athletes will want to lower it before a race but not too much because the anaerobic system produces the fast fuel for the aerobic system.
That is why there is carb loading and intake of glucose during a race. It is the fast fuel. Fats are the slow fuel. So when the anaerobic capacity is too low it won't throw off enough of the fast fuel for the aerobic system.
Quote:
The way I see it endurance athletes have a lower anaerobic capacity than sprinters because we don't train anerobic capacity not because we do train aerobic capacity. sight difference perhaps. I have never read anywhere that anaerobic capacity lowers aerobic capacity.
Endurance athletes train anaerobic capacity down with the type of training they do. It may not be their objective but is an outcome of their workouts.
Also the anaerobic capacity as measured by a critical speed test is not the same thing Olbrecht calls anaerobic capacity. They are not uncorrelated but they are not equivalent. So when I refer to anaerobic capacity I am referring to the size of the engine that is generating the energy not a measure of the anaerobic work done.
Hope this helps.
Jerry Cosgrove
Sports Resource Group
http://www.lactate.com https://twitter.com/@LactatedotCom
