Fooshee wrote:
I've never done this, but I believe there is a process to check the calibration of a powertap by hanging a known weight on a pedal and reading the torque, etc. Obviously, care needs to be taken to ensure it's done properly, but it is my understanding that you can check the accuracy of a powertap in this manner. I just assume the auto-zero function works on mine. I haven't found a need to check the accuracy.
Right. That's a static calibration check. A watt is just a Newton*meter/sec, so all you need is a known mass, a known distance, a known time, and a reliable measurement of gravity, and even styrrell can probably find those. Some PMs allow you to do static checks, like the Power Tap, the Quarq, and the SRM -- so you don't need an additional PM to calibrate against. However, some other PMs (among them, the Ergomo, the iBike, and evidently the Look/Polar) don't allow you to do static checks, so you have to check them dynamically. One way, but not, as styrrell seems to think, the only way, is to check them against a known good PM. Most manufacturers do this against a known standard dynamic test rig -- but most home users don't have access to rigs like this. So there's another way you can check the accuracy and precision in a dynamic test if you have enough other information. That was the hint that styrrell couldn't figure out.
Quote:
The guys who are performing field tests to try and estimate their CdA, etc., will need the accuracy, for more accurate numbers.
It can be done.
Yup.
And, at a minimum, you should do a static calibration check (if your PM allows you to do that) if you care about the quality of the output.
Many years ago my cousin's dumb kid bought a fancy TI-clone hand calculator with graphing capability and programmability and an enormous number of dedicated functions for a startlingly low price. As my cousin described it, his son claimed "all those features more than make up for the fact that it's missing a key for the number '9.'"
Features are nice. Being able to check the accuracy of your PM is like having the 9.
