In Reply To:
"Everything else being equal" - but that's rarely (if ever) the case outside of a lab, and you specifically said HR is a good way to evaluate efficiency outside of a lab.
Wow! you don't give the average person here much credit do you. The average person here who owns a power meter or a computrainer or some such thing. A simple calibration and a ride indoors at the same time of the day, etc. etc. and conditions are the "same" every bit as good as can be done in the lab.
In Reply To:
Furthermore, muscle fiber type does have a bearing. And it's regularly measured in the lab.
Show me a single study of cycling efficiency that looks at the effect of cadence on cycling efficiency where they also did muscle biopsey to determine fiber type. I assume there might be one but I suspect it will take you awhile to find it. In the meantime there are lots of studies that never look at fiber type. While fiber type is "regularly" measured in the lab it is rarely measured in the exercise physiology lab. The reason being is determining fiber type is invasive and involves risk and takes special skill to obtain. Such studies require institutional review board approval and few researchers are willing to go to the grief to try to get that approval unless it is integral to what they are looking for.
In Reply To:
As is power output. As is VO2 consumption. Interestingly, in none of the studies or abstracts I read, did I ever see ANYWHERE that HR was used as a relevant tool.
Well, HR is not a relevant tool for a study because the researcher is looking for numbers that can be subjected to statistical analysis. The individual isn't particularly interested in that ability. It is enough to say "this is better", "this is worse".
In Reply To:
Now HR and VO2 definitely *can* correlate. But it's not for certain - there are ways to change HR without changing VO2, fatigue being one of the big ones.
Again, you don't give the average person much credit here. Usually, I suspect, most people would do many trials in doing such an evaluation. I guess if you simply do one trial it could give a false result. I mean, how does anyone evaluate the effects of training? How does anyone do testing? Fatigue is a variable in all testing, whether one is measuring oxygen uptake or just HR.
In Reply To:
And I don't see how it's possible to maximize efficiency "regardless" of fiber type - unless you are talking about necessarily keeping power/cadence constant, which is unreasonably restrictive. That's sort of the whole point of this article - that you can change your cadence when you ride a bike. Changes in cadence, power, etc. all can change muscle recruitment. Requirements for speed of contraction changes the recruitment fibers. So the idea of maximizing efficiency "regardless of fiber type" doesn't make any sense to me, unless you were assuming I was talking about fiber type breakdown rather than recruitment. I don't see how that could be the case, since I specifically said that you want to maximize the percentage of type I fibers being
used, since it's well documented that they contract more efficiently. As for a conconi protocol, which I HAVE done, remind me again where they are done? Oh, that's right. In a LAB. In a controlled environment. With a POWERMETER (at least for cycling). And all I really wanted from you was this,
HR cannot be reliably used to measure efficiency without a way of measuring power. Power could be estimated by using speed or RPE as a substitute but power is part of the efficiency equation. Wow. I have done Conconi in my garage. John Howard did a Conconi protocal testing on me at a Tri camp at a tennis resort. Conconi protocol can be done anywhere. You don't seem able to think outside of a paper bag let alone the box. To determine "efficiency" for my purpose requires knowing power. Have you read what I have written?
In Reply To:
I'm perfectly willing to let you use speed and RPE in the field as a substitute for power, since I think it's pretty well established how reliable that is. I understand efficiency quite well. I just wanted you to admit that 1) you needed to somehow evaluate power and 2) that you think speed and RPE are reasonable substitutes in the field for power. Yes one needs to know power. Speed and RPE are not reasonable substitutes for power for this purpose IMHO.
In Reply To:
I think the latter assumption is quite flawed, and most people who train with power would also say it's quite flawed. I agree, see above. Where did you get that I thought otherwise.
In Reply To:
So basically you are taking HR as a substitute for VO2 consumption and speed & RPE as a substitute for power, and you think that is a reasonable way to estimate efficiency? That's accepting a lot of error - unnecessary error in today's world. I think it's *a* way to measure efficiency, but I think it's a crappy one that is ripe with the opportunity for error. Obviously it can work "ok," but there are massive chances for error, the most notable that I can think of being HR suppression over a training period and HR variability with weather. But power and RPE - ignoring HR - is a much better way to gauge training, which is why having a powermeter has replaced having a HRM for people that really care about training. I'm not saying that HR is useless. But it has a whole host of limitations that power does not, and once you have power, HR doesn't really seem to add anything over RPE. Go back and read what I have said. HR is simply a substitute for O2 uptake, not power.
In Reply To:
You also can't have it both ways with the Coyle study. You can't say that Lance did improve his efficiency, which the Coyle study says, but then ignore why Coyle says he did it - changes in fiber type.
I know what Coyle hypothesized. But, Coyle was guessing as to why he had improved his efficiency. Notice Coyle did not have muscle biopsy data to support his contention. It is possible, I suppose, but we would expect that every rider starting at his level (world champion) who trained similarly to Armstrong for the next 8 years would see a similar increase in efficiency. That has never been shown before. In fact, this increase in efficiency was so remarkable it was the only change worthy of not in the data. Coyle is of the bias that pedaling style cannot affect efficiency. But, he had to come up with an explanation to explain the improvement he documented. He came up with the only thing he could that didn't go against his bias, even though it made essentially zero sense. The fact that such changes has never before been demonstrated in an athlete like Lance and one cannot say what must be done to reproduce this change in an athlete like Lance should give one pause in accepting Coyles hypothesis as fact.
The interesting fact we know now (thanks to the CTS article) is that Armstrong set off to deliberately change his pedaling style to improve his efficiency. Take your choice (or come up with another explanation).
Which explanation makes more sense? In Reply To:
Furthermore, the Coyle study is not considered without it's flaws. So you can hardly say it's "well documented" that Lance improved his efficiency.
It is the only documentation we have. Coyle has answered his critics. He thinks the data is good. His critics also have agendas as they need to show Lance could have only improved using drugs.
In Reply To:
Furthermore, if it really did take him 6+ years to change his pedaling style, why wouldn't he release it? As you claim, it's a long process, so it's not an advantage that he'd give away quickly.
I don't know, why don't you ask him or Carmichael. They say they have done this but haven't given you the data you need to believe it. Ask and I'll bet they ignore you, but you never know. Perhaps it is because he became aware that there was a device that became available that would allow one to make these changes much faster than it took him. His 6 or 8 or 12 year advantage would quickly disappear.
In Reply To:
He didn't keep many more "top secret" projects from his TdF campaigns a secret in his book. Somehow changes in pedaling efficiency - which there is basically no support for in the sport or in any study on Lance - would be the one secret he'd keep? If it really was pedaling efficiency, why not just show it and be done with it.
Well, he isn't keeping it a secret now since the Carmichael article. It just so happens you don't believe a thing they say.
In Reply To:
In my *opinion*, the takeaway (if there is one) that makes the most sense from the Coyle study is that it is aerobically optimal to bring bring required contraction velocity closer to the contraction velocity of type I fibers, which is is well established contract more efficiently (but with less velocity & force of contraction) than type II fibers. That's the seeming paradox of a higher cadence - muscle contraction speed is actually slower.
Your kidding again, right?
In Reply To:
This *could* also explain why, for example, it is anecdotally reported that women tend to do better with a lower cadence (relative to men) - they are riding the bike for longer, therefore the %FTP power they are riding at should be lower, meaning the required % of maximum force required is lower, meaning that a lower cadence could work better. Since cadence and effort seem - if left solely to RPE - to track reasonably well among elite cyclists, then it would make sense that female Ironman athletes should pedal a slightly lower cadence than male Ironman athletes, since they are out there - even in Chrissie's case - substantially longer than the men.
Well, I would have an alternative explanation, one that actually makes sense and is supported by the scientific data but that would be for another thread.
In Reply To:
What on earth do you mean I don't think highly of Brett Sutton's coaching? That is a total fabrication, and it's also totally irrelevant. My original point was that Chrissie's advice could be read as "I trust what Brett Sutton has told me because it works for me, so I've never had any reason to doubt it or to try to change it." THAT, as advice, is much more relevant than the totally contextless advice to "push a big gear," which doesn't really mean anything anyway. I am pretty sure Cancellara pushes a big f'ing gear when he time trials at 95+ rpm. There are things I disagree with about how Brett Sutton coaches, but I would hardly say that I don't think highly of him as a *coach.* He's one of the most successful coaches of all time. But coaches have a knack for "doing what works." I.e., it seems to "work" to have female athletes pedal a low cadence, though it's not universal (Hillary Biscay, for example, finally won an Ironman after she upped her cadence per Dan's recommendation), and Brett actually sets a cadence cap of 84, which is not atypically low by any means. However, it is Brett's speculation as to why that is - and that is what Chrissie is echoing - not the byproduct of any sort of comparative or rigorous study. Why not simply say "I pedal a big gear because Brett saw success having lots of athletes before me do it, and I have success while doing it, so I've never been motivated to change." That's really a very accurate and thoughtful statement, that's much more intelligent than "I push a big gear because it gives me a lower HR," which doesn't really mean anything, and is also, IN MY OPINION, misleading. But there's a big difference between not thinking highly of Brett's coaching methods and disagreeing with his reasoning. Just say "I do it because it works. I'll figure out the 'why' part later." There are many coaches that do that, especially when results and what science says *should* be the case differ. And there is nothing wrong with that.
I really don't know what you think of Chrissie or Brett. I can tell you I thought your original post taken from on professional about another and her coach was extremely disrespectful and inappropriate. I think most athletes here would understand the advice means to "push a big gear" as opposed to "spinning". Even though neither involves an actual number I think most know the meaning.
In Reply To:
Thanks for the Italian study - though it's just an abstract, not a study. I will admit I pretty much discounted everything that came after the first sentence, "In cycling, a circular pedaling action makes the most useful contribution to forward propulsion." That's just not the case. Unless of course, you mean that cranks should go around in a circle, which I'm fairly certain every crank does. I also don't see that they actually document how people pedal - via pedal force analysis. It only shows muscle recruitment via EMG. So at best, it shows that people who train on PCs use "more diverse muscle recruitment" at a given power output, and that the utilization of "more diverse muscle recruitment" carries over to pedaling on regular cranks. But there's still no justification that using "more diverse muscle recruitment" is better. I.e., where is the proof that pedaling that way offers any improvement over "mashing"? That conclusion is stated, but it's missing any support.
I.e. power was held CONSTANT. They say that you "save your quadriceps," but where is the proof that these cyclists enjoyed any sort of increase in time to exhaustion as a result? What do you not understand about the scientific process. Apparently everything. Here was the "aim" of the study: "The aims of this study were, first, to assess whether the intermuscular coordination pattern of the pedaling action with normal cranks (NC) is modified after a training period with IC and, second, to determine if the new coordination pattern is maintained after a washing-out period." Why are you looking for "
proof that these cyclists enjoyed any sort of increase in time to exhaustion as a result?" from this study. Anyhow, a link to the entire study was provided should you desire to read it. Further, a link was provided to a "slide show" presentation of the study but it is in Italian. Anyhow, you asked for evidence, as I remember, that PC's change the coordination pattern. The study provided provides such evidence. Of course, your bias was shown again by your comment "I will admit I pretty much discounted everything that came after the first sentence" that had nothing to do with your original question or what was found.
In Reply To:
I've never said to anyone that PowerCranks could not have been a part of why they improved. Training is about physiological load. If PowerCranks recruit more muscles WHILE YOU ARE USING THEM - which I think is reasonable since you have to lift the crank - then that's going to increase the load on your body as opposed to not having to lift that crank. But you could also just go out and pedal harder on your regular cranks, which would also increase the load, increase muscle recruitment during a normal pedal stroke, and would also help you train the way that even most powercranks users plan to race - on regular cranks. That's what the high level athletes I know have reported, all of whom only used PowerCranks in the winter. When they trained with PowerCranks, their running and cycling fitness was no different than when they didn't use PowerCranks but did specific power intervals on the trainer and treadmill instead. PowerCranks cost approximately the same amount as a PowerTap (the cheapest PT on a wheel is 1099, IIRC) vs. $899 for the cheapest powercrank. And a powermeter offers all the benefits of powercranks plus a whole lot more, like the ability to monitor effort during all training, racing, etc. PowerCranks certainly can help you improve. But I am pretty sure you can pedal harder - which also recruits more muscles and recruits them as you are going to use them during a race - without using powercranks. It's not that PowerCranks *can't* work. It's just that there is no proof that they actually do anything unique. I.e., there is no proof that they change how you pedal when you are not using them, save for the abstract you posted. But even if they did, there is no proof that change is an improvement. Change doesn't mean improvement. There is no proof that it's better to pedal the way that you must when you are using them. And it's well documented that the best cyclists in the world pedal a certain way, and that way is neither using PowerCranks for racing nor pedaling the way that one must pedal when using PowerCranks. So you can either recruit more muscles in a fashion that is atypical of the best riders in the world by using PowerCranks. OR you can recruit more muscles in a fashion that mimics the best cyclists in the world by just pushing harder. Working harder always gets results. Training works. But it's been well shown that training in the manner that you intend to race is what yields the best success. If you want to dispute that last part, have at it.
How is it that a PM changes one pedaling style? You say a PM offers all the advantages of PC's. About all PC's do is change how people pedal a bike. How does a PM do that again if they "offer all the benefits of PowerCranks plus a whole lot more". PC's do something different than a PM in my opinion. They are complimentary IMO. And, I agree that training the way you intend to race is what yield the best success. It is why I continue to harp on PC users to use them exclusively. The only reason to get PC's is if you believe there is an advantage to pedaling in the PC fashion (or if you are looking for the run benefits). If you believe there is such an advantage then you should train on them in a manner to allow you to race as you train. If you can't do that then the benefits will be less than optimal. Put you head in the sand and ignore the potential. And, you can't be afraid of hard work if you take them on. Many give up on them as being "too hard". So be it, PC's are not for whimps.
Frank,
An original Ironman and the Inventor of PowerCranks
