phil485 wrote:
Titanflexr wrote:
The base bar and pads should be put in the best position for your fit; the gap between them is an output, not an input.
For the base bar, aim to recreate the hoods position. You only use this for climbing/braking/cornering, so being comfortable and having control are more important than being super aero (that’s what the aero bars are for).
Just putting my first TT bike together. interesting to put base bar at hood height, was thinking drops. just waiting for a few bits before trying to get an initial position sorted.
A proper bike fit might be tricky this winter
A lot of cyclists set the base bar up as a drops position. IME this harkens back to the pre-aerobar days when the base bar was as low as possible to get aero (see Roche below).
Looking at what the basebar will be used for (vs. the extensions), hoods seems to make a lot more sense (especially if the course has significant climbing). Even more so given that you need to be able to run off the bike, and that 70.3+ races have bike legs that are significantly longer than TdF TTs.
Here's Frodo. His base bar setup produces a more upright position than the aerobars; more akin to hoods.
ECMGN Therapy Silicon Valley: Depression, Neurocognitive problems, Dementias (Testing and Evaluation), Trauma and PTSD, Traumatic Brain Injury (TBI)
