mikemelbrooks wrote:
Unfortunately there are more variables, the greater the relative air speed the the more a narrow set up will come out ahead because aero drag goes up by the square of the speed while rolling resistance goes up linearly.
Also weight of the rider and bike I am assuming that a heavier rider will absorb more energy being shook around that a skinny one.
If Zipps marketing is to be believed they now test in the real world where the wind doesn't always flow at a constant rate and interacts with the environment.
Fair enough. I've been thinking about this a little as well and you are correct - trying to manage all these variables in a single study would be a little too complicated.
So to elaborate a little more on what I was getting at - one part would be to get a sense of the aero differences between wide and narrow (as asked earlier). Yes, wider is universally accepted as faster at yaw - I am just trying to learn a little more about it: what drives it, what is the magnitude of the improvement, etc.
The other part would be trying to understand the correlation between optimal tire pressure for a given width and overall rolling efficiency. Let me elaborate here.
The Silca blog and Tom A's posts make it very clear there is an optimal tire pressure at which increasing the pressure further results in a significant loss in efficiency, due to what Zipp calls Vibration Losses in their white paper. For a 25mm tire, that optimal point is around 100-110psi on smooth asphalt. So far so good.
So what happens if you go to, say, a 28mm tire? The Crr curve is going to be lower (lower Crr at a given pressure). But what is the shape of the Vibration Curve? Is it the same curve (ie, unaffected by tire width), is it lower or is higher? Because the shape of the curve will have implications on the tradeoff between tire size and pressure.
See below:
Depending on what the Vibration Curve looks like for a 28mm tire, there are insights to be gained about both the optimal tire pressure for a wider tire, as well as how it compares to a narrower tire overall, as far as rolling efficiency goes.
I realize that this is a very academic exercise, but there could be useful insights here. Eg, for me, a big take-away from Tom A's analysis is that it is better to err on the side of too low pressure than too high. Here, understanding the magnitude of the differences will allow some basis for comparison with aero drag numbers.
Does anyone know how the vibration curve/impedance curve changes with tire width?
(And it could be that i am just a knuckle-dragging mouth breather, but i have been trying to google this for a few days now, but havent found an answer).
Those who are slower than me suck.
Those who are faster than me dope
