I have that same bike . There are <10 bikes in production that I would get rid of that bike for. Assuming it's
this bike. You also sound like me when it comes to 70.3 and the regional racing scene.
Here's what I did to mine to make it fast. call it <5 watts behind a P5-6 fast on the yaw sweep.
Upgrade it to 11spd. buy some super slick aerobars ( originally I went with the profile aeria ultimate then switched to the tririg alpha one w/gamma extensions) there is no aero advantage of one bar over the other on a 0 to -10 yaw sweep fwiw
Then I moved the rear brake cable, rear & front derailleur housing internal, routed through the frame just behind the stem. I placed the junction box behind the stem. It is hidden from view by the BTA & bike computer.
Then I added a tri rig front brake. You can also go with the Vision Tri max. That brake is <1w slower across the yaw sweep vs the tri rig. It may actually be faster since I tested that with a cable and the tririg without cables. But I'm lazy and left the tririg on since it was the last brake I tested that day.
I dropped the battery for the electronic shifting into the seat tube. I run a single behind the seat bottle for my flat kit. For racing I go w/a BTA and downtube bottle since on my medium there is not enough of an aero penalty to worry about, if any.....ask me how I know haha!
(FWIW the plasma 3 in size SM takes no aero hit for a downtube bottle in numerous tests with numerous people and is usually neutral or 1-2w slower in size Med, again I've tested this on multiple scotts with multiple people. Going to a large though....don't put a bottle on the frame for racing.)
I run a rear hed disc with a PT hub and Hed jet 90 on the front for racing. Use to use a zipp 808 fc but I need every watt I can get now that I'm getting older and this change got me more than 1w haha.
It's faster than a stock Plasma 5 even although that has better integrated storage.
Basically I can walk into any 70.3 and in my AG & know there are < 10 bikes faster than mine in the AG and probably less than that after you examine how they place their bottles, flat kit & nutrition.
The bikes I know are faster than it off the top of my head include the Cervelo P5-6, P5x, P3x, Trek SC. It is 1w slower or faster than a premier tactical at -5, -7.5 & -10 yaw (a bike I would take a hard look at if I was upgrading, best bang for the buck imo).
I've heard rumors that the Cube Aerium is between a SC and P5X. When I try to get data it's person A sending me to person B then to person C back to A. Then there is probably the new Merida Warp TT, maybe.
Unless you're bike is damaged you could make it extremely fast, faster than a bunch of other, most other bikes currently out there for <$2k
If you have the same bike PM your email address and I'll shoot off some pics in case you want to undertake this project.
Brian Stover USAT LII
Accelerate3 Coaching Insta
