rruff wrote:
Can you avoid the braking by going up hill?
Will Aerolab work with that sort of protocol? I'm not sure what you are describing. It sounds like repeats of a point to point run...? I thought your protocol used continuous data.
Um, no, it'll work with point-to-point runs. However, with Aerolab you either have to squint to block out the segments where you returned to the start or else you'll have to cut-and-paste. One wish for the wish list is for Aerolab to be able to "stack" runs on top of each other (another wish is to "mirror" out-and-backs"). If you could stack you'd just line up your two (or more) runs and find global estimates of CdA and Crr that make the VE profiles match. A check would be to compare those two (or more) profiles with the actual one.
In my case, when I do odd things like one-ways up a hill or straight out-and-backs, I drop into special routines I've written so I can either stack or mirror.
But, yeah, the protocol works on any terrain, and for loops, one-ways, or out-and-backs. I think I give an example on slide 42 of that presentation. With this protocol, you can use flat or not flat, constant speed or variable speed, one-way repeats or loops or out-and-backs, climbs or coast-downs.
