That's tough to say for me. I am not familiar enough with the two products to have an informed opinion on both of these.
I will say this, these are the criteria I look at in a tire, and I have a bit of a tire fetish:
This is an exceptionally good thread. Tires have more to say about a bike's ride quality than frame material and they are an inexpensive and highly effective upgrade.
Tom Demerly
The Tri Shop.com
- How is it made? Is this a hand-made "open tubular" construction or a more automated manufacturing process?
- What are the materials the tire is made out of?
- How many plys? What are the various ply layers made out of and why?
- What is the TPI count: Threads Per Inch offer some insight into the density of the tire's casing weave, a strong hint at it's ride quality. Generally, higher=better. Currently, Vittoria is one of few companies that label their TPI count on the packaging clearly. That is a good idea, but I wager few consumers understand this information.
- How much does it weigh? Weight is a factor in tire performance. To a degree, lighter is better. That said, a tire can be made so light they are too frail for general use.
- What is the durometer of the tread material? Hard? Soft? Multi?
- Tread pattern? What is the idea behind the tread pattern?
- What is the real size of the tire? (Not the manufacturer's claimed size on the label). Not all 700X23c tires are the same size.
- What is the bead diameter tolerance? How does it mount?
Tom Demerly
The Tri Shop.com
