Hoodoo wrote:
I was to choose the Corsa but felt the Speed triathlon was worth a try...
I'm not sure how many people outside of Vittoria could say with 100% certainty. The short version of my guess is that the Corsa and Speed Triathlon appear are nearly the same except the Corsa has a latex tube and the Speed Triathlon has a butyl tube.
The Speed Triathlon appears similar to the tires you flatted on, except butyl inner tubes and the website hints at increased protection with a different casing than the original Corsa Speed. I don't understand why they made it. Butyl tubes slow it down and it is either fragile or the same rubber as the Corsa. It seems it was created so somebody could pump up their tires the day before their race and not have to worry about PSI for their event.
The
Corsa tubular (I don't think they call it Corsa G anymore) definitely has more puncture protection and tests about 3 watts per tire slower than the Corsa Speed at the pressures people are realistically riding. It also has a latex tube. It's really hard to guess if it's more puncture resistant than the Speed Triathlon, but I would think so. A "Speed" with a butyl tube only becomes one watt faster than a Corsa, but Vittoria seems to be saying they are using a stronger casing for the Triathlon Speed. That probably knocks it down a couple more watts and makes the Corsa a better choice. They are
probably very similar tires with the inner tube being the main difference.
