Menglo wrote:
From a design perspective disc brakes make sense as you now have components that serve ONE purpose, stopping the bike. Currently, wheel manufacturers HAVE to make compromises in order to develop wheels that balance weight, aero, and braking performance. There is NO such thing as designing a product that performs 2 distinct tasks perfectly.
Ummm, plenty of great engineering is having a component perform multiple functions. Yes, a single component may not perform two distinct tasks perfectly, but it may be a better solution than having two separate components. Yes, getting rid of braking on a the rim may increase the performance of the rim itself, but will it increase the performance of the wheel itself? Of the bike itself? Just looking at the wheel, the new wheel shapes, I do not see how getting rid of braking would make the wheel more aerodynamic, the shapes really do not care about the brake track. And you need to add more spokes to a front wheel, so now the wheel is less aerodynamic as a whole. And that is without figuring in the extra aero drag of the disk, sure you could make the disk more aero dynamic, but then you decrease the cooling of the disk. Sure you could make the disk more aero-dynamic, but then you have to figure out the heat issue, so you can add a bigger disk which will be heavier. This is even without talking about the caliper and its cooling. People keep talking that integration will solve this issue, but I am not sold on this because shielding the caliper from the wind is going to cause heat issues. When you brake you have a certain amount of energy you need to turn into heat. With disks brakes, you put this energy into a small amount of mass, which means the temperature is high. The bigger the disk, the lower the temperature at the end of braking. So to reduce aero drag, you may want a very big disk, so the caliper can be small and be very aero because it does not need much cooling since the temperature is low. Well at this point, maybe it makes sense to use the largest disk you have, the rim itself.
I think people in this thread that a less keen on disk brakes understand compromises very well. They are the ones asking if a possible improvement in brake modulation is worth the costs.
Disks may make sense, but right now there is nothing
