OK, so I tried to glue up my Zipp tires onto my 606s. Anyone who says this is no big deal is insane. I am a pretty good wrench, have rebuilt cars and houses without worry. But this, well, this sucked.
1) Apparently, gluing the base tape takes away a HUGE amount of stretchiness, or actually shrinks the tape. When I pre-stretched tires, they went on (and rolled right off, even when inflated) with easy thumb pressure. When I glued them on today, the battle was absolutely fierce to even get close. I never could get the rear one on.
2) I got the front one on, but by then the glue on the rim was pretty much dry. Sure, where I had applied it a little thick, it was sticking. But it was not a clean stick all the way around. And the tire is way too tight to peel back and insert more glue. I inflated it, spun it. It looked straight, but had a huge hump near the valve that makes the wheel bounce up/down in your hands as you spin it. Super. Can't do anything about that either.
So, I tore the tire back off and am staring at $2500 worth of glued up mess in my garage. Now WTF? Should have gone with clinchers. I knew it.
Too f@ckin depressed from various injuries to care about having a signature line.
Sponsored by Blue Shield PPO.
