I know there was thread on this can not find it. Extensions on the mono post keep coming loose. Blue lock tight did not help. Seems I read there is something wrong with the fastening screws on some bikes. Any help would be appreciated
Re: Trek speed concept extensions keep coming loose. [rhudson]
Somebody can better express this than I will, but you likely will need to disassemble everything from the aero bar up. There are some floating receiver nuts in the height adjusting unit. You likely lost the connection on one of them.
rhudson wrote:
I know there was thread on this can not find it. Extensions on the mono post keep coming loose. Blue lock tight did not help. Seems I read there is something wrong with the fastening screws on some bikes. Any help would be appreciatedAre you making sure the the little tiny set screw is in firm contact with the stem? This little piece doesn't seem very important but it is IME.
Try Red Loctite instead of blue after addressing the other problems stated above
"I swim because that's how I get to ride my bike."
