Is anyone else having trouble with their TrainingPeaks custom workouts not loading in Zwift since yesterday? I saw others have this problem on the Zwift forums too but no fixes. If you are having this issue, have you heard of a fix?
Re: TrainingPeaks workouts not loading in Zwift [ashmilner]
You should check to make sure your zwift and trainingpeaks accounts are still linked. Go to zwift.com and log in, then go here:https://www.zwift.com/settings/connections and make sure all your connections are still there. I've had my strava and trainingpeaks accounts become "unlinked" for some reason in the past month. Seems to happen periodically.
http://www.savagesentiments.blogspot.com/
http://www.tricoachmartin.com/
https://www.facebook.com/teameverymanjack
Make sure your Training Peaks workout has a name (an actual title for the workout). Without the name, Zwift won't recognize the workout.
I had the same issue yesterday. I saw some old forums online where someone suggested it had to do with the time change. I ended up manually adding my workout so I could do it and am hoping it is working again tomorrow.
I had the same issue. I was able to manually load it in by grabbing the .zwo file and putting into the folder on my computer under my documents.
you have downloaded a new workout file and want to use it in Zwift, simply save it to Documents/Zwift/Workouts/YourZwiftID (where “YourZwiftID” is your Zwift ID number), then start up Zwift. Your workout will appear under the “Custom Workouts” category in the workouts list.Feb. 9, 2017
And it worked. Bit of an extra step tho that took me a few to find
