Gatineau Gator wrote:
Hi fellows,
I just downloaded TR for the first time and did the FTP Ramp Test. I lasted twenty-minutes and made it to 245 watts. It says my FTP is 177 watts.
Is there a webpage somewhere that provides some comparisons of FTP, so I can get an idea of what this FTP number represents based on age, gender, etc.
Thank you in advance,
GG
I found the ramp test gave a masively optimistic result for me when compared to 20min FTP test, and that too gave a high value compared to what I can do for an hour. FTP tests, especially shorter/easier ones are not, IMO, very comparable between athletes of with very different training backgrounds and different strengths/weaknesses.
I've done 20min efforts around 310-315W (so FTP calculated as 95% would have been about 295-300W), I did a couple of ramp tests and got a calculated FTP of 315W (by Zwift but I think it's the same protocol?). I haven't often tried to ride flat out for an hour, but when I have I've never exceeded 274W.
These tests weren't all done within a few weeks, but my ability was pretty similar across all of them and there's no way my FTP varied by 40W, I'd say 10W maximum and probably no more than 5W. During that period I trained based on guesstimated FTP figures of 280-285W.
Also, bear in mind that you can get better at executing FTP tests and achieve higher values, even without being fitter. Having a realistic idea what you're aiming for and being accustomed to subjecting yourself to really hard efforts on the trainer can allow you produce much higher numbers.
