Tips for removing a stubborn pedal?
So last night, I managed to strip the bolt on my left pedal trying to remove it from the crank arm. I have a good, large, Park Tool pedal wrench and just could not budge the thing.
Any tips for getting that puppy off? My bike box won't close!
Thanks!
Busted knuckles in New York,
Adam Duncan
New York, NY
Re: Tips for removing a stubborn pedal? [aduncan] [ In reply to ]
Is'nt the left one reverse threaded? one is the opposite, just a thought.
make sure you are turning it in the right direction! Assuming you are, it might be seized. Try penetrating oil or if you have a torch, a touch of heat to the crank only, not the spindle of the pedal
Re: Tips for removing a stubborn pedal? [tristeve] [ In reply to ]
Thanks for the responses. I think I may have been turning the wrong way. What a jackass.
Thanks again.
Adam Duncan
New York, NY
check that crank, if you really crank on it, no pun intended, you could have cracked it if you were turning it the wrong way, it would split at the top.
