MrTri123 wrote:
James2020 wrote:
LT1 at 93% of FTP is off the scale high compared to the tests I've seen. Around 75% of FTP is more normal. If you can't get a lactate test I'd just use zone 2 of coggins 7 zone model as your low intensity training zone (56-75% of FTP),not perfect but likely good enough.
If you are really serious about training a lactate meter is not a huge investment in the grand scheme of things - it is equivalent to two lab testing sessions here in the UK so you make your money back pretty quick. Probably uneccessary for recreational athletes, but if you really like the numbers and knowing for sure you are in the right zone go for it. It's not particularly difficult to use.
As for using ear for blood sample it tends to be standard lab practice. Not because it provides a better blood sample - finger is fine. It's more just practicality of it being an easy place to access compared to fingers which may be on handlebars on a stationary bike or moving around much more than the ear during running on a treadmill. Secondary reasons are some people are a little squeamish and not being able to see any blood works better for them, and some people moan about fingers being sore (ear probably bruises just as much but not really noticeable as nothing coming into contact with it).
Great info thank you!
I agree meter, test strips and lancets not too ouch if an investment
I want to make sure to educate myself before getting it
Any book you would recommend to educate myself?
As for the 93% maybe he was saying that for LT2?
Finding the zones is pretty easy (although there is some disagreement even there). The more complicated part might be how you use that information to program training. There are a few different ideas, and honestly I don't think there is enough evidence to say any are better or worse. It's generally accepted (by the athletes using lactate at least - trainer road and others may disagree), that most training (80-90+% should be below LT1. Exactly where the other 10-20% should be is perhaps not so clear. Traditional polarised training would say it should be above (and in some cases considerably above) LT2. However some suggestion (especially for longer distances) intervals just below LT2 are preferred (reasoning being you can spend more time at that intensity, recovery is quicker, perhaps they replicate race pace more, and seem to be popular with the Norwegians who are the trend right now). Some also say you ideally train at exactly LT2.
For calculating zones
- sit on bike ready to go and take a resting lactate measurement
- cycle for 4 mins at a very easy pace 40 or 50% of FTP is not unreasonable think of this partly as a warm-up. At the end of 4 mins take a lactate measurement (don't be surprised if this measurement is lower than resting sometimes a bit of gentle exercise can lower it).
- increase the power (erg mode is ideal for this, but try to maintain same cadence throughout), ride for 4 mins, take another measurement. Keep repeating this process untill you have 2 consecutive measurements over 4mmol/l.
- where lactate first rises above 2mmol/l can be used as LT1 power and HR. Where it rises over 4mmol/l can be used as LT2 power and HR.
In terms of how much to increase power each 4 mins. Smaller increases will give you a more accurate prediction of exactly where your thresholds are. However, also means a longer test. Around 10 steps from warm up power to FTP power tends to work pretty well IME i.e.
FTP = 300 (I'd probably round it to the nearest 10 just for simplicity it doesn't matter for the test results)
Start at 50% = 150
Power increase per step = FTP - start power / 10 = 15
So your planned test powers would be 150, 165, 180, 195, 210, 225 etc. Just keep going until you get two measurements of 4mmol/l.
If you really want to get super exact you can always retest i.e.
Test 1 results
210W - 1.8mmol/l
225W - 2.2mmol/l
So then you do a 2nd test where you measure lactate at 210w, 215W, 220W, 225W. Honestly it seems overkill to me I'd just use 210W but it's an option if you want.
You then need to do it running too as the threshold HR are often different and it's perhaps better to know thresholds in relation to running pace than HR anyway. Find a track and use pace instead of power and repeat a similar step test.
