Hi All,
I'll be doing my first Ironman this fall and I'm seeking a front end solution to address three factors, the most important being #1:
On point 3, I need a bit more front end length / adjustability. I have 120mm stem and I'll be swapping out for a 130mm stem, but would like a bit more extension length in case I need more reach.
These are the extensions I've researched thus far. They all provide some arm support:
I've also considered longer arm pads, like Tririg's arm cups, to allow to be shift forward if I need more reach. But I'm not sure if they'd work with extensions that have arm / wrist support.
Last, this is my current setup:
Any input is appreciated. Thanks!
- Works with mechanical 105
- Comfort
- Fit / length
- 51 Speedshop Rev (70mm rise)
- Wattshop Minimoi Extension Poles
- Profile Design 43 ASC Carbon Extensions
- PD Wing/20C
- PD Supersonic J5 Bracket
- PD Sonic Ergo 35a
- PD Aeria Hydration system
