SuperDave or Tom D???
Guys, I put the Tufo Sealant in my tires a month ago. How often do I need to add more? Will the stuff i already added last for a year or is there a time frame I need to reload? I think it did the trick at the Steelehad this weekend, I heard a real short, quick pssshh then nothing? Should I replace the tubbie or trust that the sealant will hold?
Thanks Guys!!
Re: SuperDave or Tom D??? [Ken in Mi] [ In reply to ]
I'm kind of wondering the same thing. Also I'm wondering if you can use "Stan's" sealant, commonly used for tubeless mt bike tires. Anyone know?
Re: SuperDave or Tom D??? [beatnic_tx] [ In reply to ]
SuperDave is a dealer for Tufo. he should be able to answer
Bump....
Ken, what psi do you run in your Tufo's? Are they the tubular/clincher or just sew ups?
run tufo tubbies at 150 psi
The sealant sounds like it did it's job. I use it as a preventative measure as well, Once it has sealed a puncture, there is no way to know how much is remaining. Squeeze another ounce into the tire to be safe.
I don't race on fixed tires, but I don't patch inner tubes either. That is a judgement call.
I haven't used Stan's but I assume it would work.
-SD
https://www.kickstarter.com/...bike-for-the-new-era
Re: SuperDave or Tom D??? [SuperDave] [ In reply to ]
What SuperDave said.
I use the stuff. Works good.
Tom Demerly
The Tri Shop.com
