[reply]We were taught that high ankle sprains can cause pain and discomfort for up to 6 months. Sounds like you are functioning pretty well if you are doing all the runs you listed from recovery to sprints. How long is the pain lingering after you run?
Doesn't sound like RSD. One of the hallmarks that I look for is pain out of proportion to the injury. If you are running speed work and long runs, I would highly doubt that you truly have RSD.
If you have doubts, definitely request the MRI, at the very least it will give you peace of mind. Joint manipulation, as mentioned by cerveloguy and others may of benefit. Just read a case series on calcaneocuboid syndrome, fairly uncommon, but responds well to manipulation.[/reply]
Pain out of proportion to the injury is not the only hallmark of an RSD. RSD can be relatively (or completely) painless but have other manifestations. (I once saved the finger of a marine whose trigger finger was constantly blue from poor circulation with no obvious etiology and no pain. They were going to amputate it and I "cured" it with two sympathetic blocks in a "just to make sure" move before it was lopped off). Another manifestation is a movement disorder which, again, can occur without much pain.
The other "hallmark" of RSD is something that lasts out of proportion to the "injury" (the inciting trauma can be so minor as to not even be remembered by the patient). Something lasting for 6 months, or 2 or 10 years without explanation or response to treatment is almost certainly out of proportion to almost every trauma. I always think of it as a possibility in these situation. Failure to think of it can sentence the patient to years of pain, especially when the diagnostic test is so easy to perform, at least in the right hands.
In my role as a specialist in treating chronic pain I saw everyone else's failures and I can tell you the most common reason for chronic pain is a missed diagnosis and the most common missed diagnosis is RSD.
Frank,
An original Ironman and the Inventor of PowerCranks
Frank,
