I am thinking to buy the Speedfil Z4 Cage. Is there any other way to install the cage without using the zipties?
Re: Speedfil Z4 [rebiker17]
rebiker17 wrote:
I am thinking to buy the Speedfil Z4 Cage. Is there any other way to install the cage without using the zipties?Pretty sure it can mount to a mounting plate if you have one BTA on the cockpit, or install one through another mechanism.
Zipties work fine for me though.
I have the profile design aerodrink bracket but I am not sure if I can use it with the z4 cage...
The have top cap mount that I use. It can also be used for other bta
https://www.amazon.com/...-Mount/dp/B008BWMRFA
It's not great and rotates around when I forget to check if it is tight, but it's the best solution for me without switching to another system like those vertical bta
