GreenPlease: Nov 28, 18 12:13
Re: Specialized ANGI: Helmet Integrated Crash Sensor and App [GreenPlease]
DCRainmaker says $29/year subscription (first year free but give them your card info up front) is required. My RoadID app works fine straight from my phone, not sure why you need to pay Specialized for infrastructure to do the same...
I'm closer to the feathered end of the spear than the point.
David_Tris: Nov 28, 18 12:28
Re: Specialized ANGI: Helmet Integrated Crash Sensor and App [David_Tris]
Wow, people are buying a helmet that charges your card 29 bucks a year?
What happens if you hit the distress button....foes a rescue team come out or do your GPS coordinates with automated message get emailed to a list of contacts you register ?
David_Tris wrote:
DCRainmaker says $29/year subscription (first year free but give them your card info up front) is required. My RoadID app works fine straight from my phone, not sure why you need to pay Specialized for infrastructure to do the same...FWIW, The technology that Specialized has incorporated is not a tracker, it's a crash sensor. In the event that you are unconscious or debilitated, it will send an alert to those on your contact list. As far as I know, IceDot* is the only technology of this kind on the market.
If you do not want to use the feature you do not need to activate it, nor give your credit card information. Buy the helmet and use it as your normally would.
Consumers can make the choice whether it provides them value or not.
*Addition for Clarity: I referred to the asterix IceDot as such because it was the original technology. For Clarity this is the same / similar technology as in the Specialized ANGI Sensor as Specialized has purchased IceDot.
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
I also give Training Advice via http://www.ForeverEndurance.com
The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
xtrpickels: Nov 29, 18 12:28
Re: Specialized ANGI: Helmet Integrated Crash Sensor and App [xtrpickels]
The ice dot appears to be a seperate unit for about 140 bucks, you charge it after 20 hours of use or a month of stand by. It sends a signal to your phone which sends the email to your contacts. It works by detecting irregular motion during a ride and interprets if a crash might be in process
https://www.bikeradar.com/...-crash-sensor-48300/
Re: Specialized ANGI: Helmet Integrated Crash Sensor and App [lacticturkey]
Probably would help if you had read the linked article first. It has a lot of technology never in the Icedot product, and it's now $49 for just the pod. And it requires cloud access.
lacticturkey wrote:
The ice dot appears to be a seperate unit for about 140 bucks, you charge it after 20 hours of use or a month of stand by. It sends a signal to your phone which sends the email to your contacts. It works by detecting irregular motion during a ride and interprets if a crash might be in process https://www.bikeradar.com/...-crash-sensor-48300/
Specialized bought IceDot and made a sensor that attaches to their helmet or any other helmet with a double-sided adhesive pad.
xtrpickels: Nov 29, 18 12:26
