Re: Shorty Bars; What kind do you have? A follow-on to prior post [Monk]
I have the VisionTech TT Mini Clip-On's. I like 'em cause they aren't too big and don't scream "triathlete," (at least, I don't think they do), but still allow me to get down in an aero position when it's windy or if I want to practice riding in aero.
http://www.visiontechusa.com/fly.aspx?layout=product&taxid=143&pid=252
They are not super comfortable, but they seem pretty stealthy compared to regular clip ons... I like them better than the full profile carbon strykes I had on. I use them a little bit, but mostly they stay out of sight...
I'm using the original Profile Jammer GT's on my road bike. They work great for those times when group riding when I'm either pulling at the front or trying to catch the tail end if I'm being dropped. They also have a newer carbon version called the CGT. You can find both here.
http://www.profile-design.com/product_pages/clip_on/
I have the Vison Tech Mini TT on order.....
Just ordered some Syntace XXS
http://www.trisports.com/syxxsae.html
Going to set up the road bike in the slam position.
_________________________________
I'll be what I am
A solitary man
I'll be what I am
A solitary man
Re: Shorty Bars; What kind do you have? A follow-on to prior post [Cmikul]
That's the size I had in mind--but it needs the S-Bend, and it should be carbon. I don't know why.
http://www.visiontechusa.com/...axid=143&pid=252
I've used the Oval Slam bars on my road bike - love them. Do you want to borrow them to try? They're not the current high zoot style, but I think they do work pretty well. Let me know.
Cheers
Barry
Cheers
Barry
I've also got a pair of VisionTech minis ordered.
RP
RP
Visiontech minis are on my road bike as well.
Oval Slam Bars on Merlin Agilis
fal7 in Houston
fal7 in Houston
CGTs. I bought them purely on looks. I think that they're cute and they make my bike look awesome.
http://www.profile-design.com/...lip_on/clip_cgt.html
The quality control, on the other hand, is questionable. One of the bars is actually 1cm longer than the other. Huh? I don't get how that could happen...
i ride the cinelli spinacci lite, and i've got no idea why more people don't ride them. they definitely don't scream "triathlete", and are perfect for the situations you've described. i also use them for short-course and draft-legal tris. in terms of adjustability and price, they ruin the competition. and on weight, nobody competes at any price point: 195g.
-mike
(i think the site's www.cinelli.it - a very cool page)
https://lshtm.academia.edu/MikeCallaghan
http://howtobeswiss.blogspot.ch/
-mike
I have a set of the Vision Mini's. I was looking for Spinacci's, but no-one appears to stock them anymore - at least locally.
I found that the pads that come with the Vision Mini's are a bit shallow to be comfortable on for more than a few minutes, because it takes a lot of forearm "tension" to use them. I ordered a set of "deluxe" pads and plan on installing them as soon as I get home. Note that the deluxe pads come with a few risers and different length bolts, and that they are also thicker than the standard alu pad brackets that come with the minis. The problem is that they don't provide bolts for just using the deluxe pads with no risers. You'll have to cut down some of the longer bolts for to put the deluxe pads directly on the mini bars.
<If you're gonna be dumb, you gotta be tough>
Get Fitter!
Proud member of the Smartasscrew, MONSTER CLUB
Get your FIX today?
Get Fitter!
Get your FIX today?
Re: Shorty Bars; What kind do you have? A follow-on to prior post [Khai]
I had some hacked up VT's - basically the mini, but before it was commercially available. The mini pads are pretty useles, and I had trouble staying in them for longer than 10 minutes without a lot of fore arm pain.
I decided to ride my road bike in a hilly 1/2 IM, but the pads just are not comfortable enough - I even tried the larger pads from my road bike, but it wasn't working out. I picked up some Profiles with the F-19 pads - I think they are the Jammer GT's. Anyway, the pads are comfy, the stack height is perfect (I still have the hands by the stem climbing position), but the extensions leave a bit to be desired. To get them to fit me, I had to pull them off and switch them - left for right and right for left, then I turned them pretty much straight up and down. They aren't perfect, but the are good enough. Perhaps I will invest in some S-bend extensions for them at some point - they would probably be ideal for this geometry.
Kind of, yeah. I don't think it's so much of a "levering" effect as it is the size and placement of the pads. They're only about 1.5" deep (fore/aft), and hit a little forward of the midpoint between my elbows and wrists - so the muscles are under tension to keep the position. Bigger pads won't do a whole lot about where they hit the forearms, but a larger surface area would likely allow me to relax a bit more while using them.
I'll let you know once I get them installed.
Get Fitter!
Get your FIX today?
Get Fitter!
Get your FIX today?
