Shaving legs - any tips?
Hey ST, getting fast enough to be interested in shaving my legs. Tried it once 10 years ago and it went terrible - got like a bunch of red bumps / folliculitis.
Any tips on how to approach shaving down? Next race is in late May so figured i would shave now and figure it out
Thanks for any suggestions or pro tips!
Re: Shaving legs - any tips? [Yrocket] [ In reply to ]
I always use the oldest blade head I have and start with long passes going up the leg starting from the ankle.
Make sure the leg is dry so you get a clean slice of each hair.
I use an electric razor, it's pretty good! I shave all exposed hair including the arms
I use a hair trimmer without a guard. Obviously not a super close shave, but no bumps or ingrown hairs to worry about.
Re: Shaving legs - any tips? [rainstorm] [ In reply to ]
You might wanna go for the non-exposed as well
There's no aero benefit but there are some chafing issues that could be remediated, especially when in conjunction with undercarriage lubricants, e.g., Squirrels Nut Butter
YMMV
"What's your claim?" - Ben Gravy
"Your best work is the work you're excited about" - Rick Rubin
Atrocious advice above.
Step 1: electric razor to take the length off
Step 2: go to town to shaving foam
Step 3: use a hand held razor with a brand new blade, being particularly careful over the shin bone, knee and behind the knee
Step 4: moisturise a lot
Step 5: race
Re: Shaving legs - any tips? [PJH] [ In reply to ]
Nobody strops a straight razor and shaves like a real man? Nothing makes you aero like trimming a quarter inch off the front of your shin.
Actual advice: liberal use of shaving gel. Make sure your legs are really warm before you shave. Use your hand to feel where you missed a spot or two.
solid advice above from PJH. and it's not only about being fast, btw. do the full body shave, hit chest too. something i've not heard many mention, but with our inevitable multiple showers per day, waaay quicker to towel off with no body hair holding moisture. couple quick towel passes, done!
for fun, maybe look up sheep shearing competitions, those guys know how to manage time and make short work of it, watch
how fast they work. i'm sure you'll figure out how to get reasonably quick at it. (yourself, not sheep) 6minutes or so, start to
finish. Good luck Yrocket!
http://www.PatGriskusTri.com USAT Certified Race Director
2024 Races: USAT State of CT Age Group Championship/State of CT HS Champs/ CT Club Championship - Sat June 15th (Oly/Du/Sprint) Hopkins Vineyard Tri at Lake Waramaug Saturday July 13th http://www.HopkinsVineyardTri.com
We Re: Shaving legs - any tips? [Yrocket] [ In reply to ]
Cut it back to a stubble with an electric trimmer first. Then shave with the most expensive lady’s razors (one per leg) you can find using Skintamates lady’s shaving gel.
Be sure to practice on your scrotum first.
Re: Shaving legs - any tips? [BLACKSHEEP] [ In reply to ]
If applicable - I knew some female bike messengers who were non-shavers
Clippers the day before. Don't bother with shaving. Huge waste of time you could be sleeping, eating, or training instead.
Zen and the Art of Triathlon. Strava Workout Log
Interviews with Chris McCormack, Helle Frederikson, Angela Naeth, and many more.
http://www.zentriathlon.com
As mentioned, use a trimmer first, then blade shave.
If razor bumps are an issue, rub some isopropyl alcohol on when you get out of the shower. Yes it stings (a lot), but only for about 10 sec. and does the trick.
ECMGN Therapy Silicon Valley:
Re: Shaving legs - any tips? [Titanflexr] [ In reply to ]
Wax instead?
Nair with Aloe & lanolin… don’t let the pink bottle scare you. If you’re wooly use a trimmer first.
Re: Shaving legs - any tips? [marquette42] [ In reply to ]
With chemical depilatories like Nair, try it on a small section of your leg first....and not just before a race. They work great for some folks, but others either find that all the hair isn't removed or that their skin reacts badly to the chemicals. If neither of these are the case it can be a good option.
Re: Shaving legs - any tips? [re-fresh] [ In reply to ]
I do it that way for the first cutting.
Then I follow-up with a safety razor after/during a shower or bath. And maintain with the safety razor over time.
http://www.jt10000.com/
