JasoninHalifax wrote:
https://www.bicyclerollingresistance.com/road-bike-reviews?maxweight=401&max=24&min=6&minpr=24
I thought lower pressure was better? Why do tires on this site consistently, maybe universally, test better at 120psi vs 100? methodology?
There are multiple contributions to a tire's rolling performance.
One is energy that is spent deforming the tire.
When a part of the tire enters the contact patch, it gets deformed against the ground: this deformation consumes energy from your forward movement. When this part of the tire leaves the contact patch, it springs back to round, and in doing so it returns some energy to your forward movement. However, materials have internal friction, or "hysteresis": when you deform them, some of the energy spent doing so ends up as heat. So the amount of energy that is returned is always less than the amount of energy that was spent, resulting in rolling resistance.
You can minimize this effect by using higher pressure (since this reduces the amount of deformation), or by using a faster tire that loses less energy to hysteresis for a given amount of deformation.
This is the "rolling resistance" that gets measured on the drum.
When people talk about lower pressures performing better, they're talking about how the tire performs as suspension.
Think about what happens when a tire rolls over a surface irregularity. If the tire is pumped too stiff to deform around the irregularity, and instead deflects vertically off that irregularity, you're creating a vertical motion in the entire bike+rider system. This steals energy from your forward motion.
If the tire instead smoothly deforms around the irregularity, this energy loss doesn't happen. So you can prevent this by reducing tire pressure.
Reducing tire pressure
does result in greater loss from hysteresis. But even on fairly smooth roads, the energy wasted vibrating a bicycle tends to be far worse than the added hysteresis loss of using an appropriate tire pressure. So there tends to be a pressure sweet spot: you want to be low enough that your tires are working properly as suspension, but not pointlessly low.
Suspension affects depend on the particular system being suspended. They don't show up on BRR because, even though the drum is rough, there's nothing being suspended: the tire is just locked in place against the drum. A rough drum
can give higher rolling resistance values than a smooth drum, but this is just because it's creating additional deformation in the tire tread.
burnthesheep wrote:
One important takeaway on the bigger tire trend from most of these sites is that the CRR gain lies in still running the larger tire pumped up to a level that is less comfortable.
Maybe, but I'm not convinced that this is generally the case. BRR's width comparison seems to claim this in their "same comfort" test, but their way of determining "same comfort" seems to be based on a simplistic assumption of how tire spring rate works.
At least in static testing, tire deflection against small deflectors is far less width-dependent than it is for flat surfaces. Which would seem to imply that, if a 23mm tire and a 32mm tire are deforming by the same amount against the floor, the 32mm tire will deform
more for finer surface irregularities and would thus likely be "more comfortable."
What might be useful is a precise survey of breakpoints for tires of different widths of the same bike+rider and road.
