Hi everyone! Any experience on how to best facilitate the return from ITBS.
The problem first appeared about a month ago, probably because of a sudden jump in vertical distance during running (finally moved back into the mountains). I stopped running right afterwards and tried again a week later but only made it about 3k and stopped at the first symptom. Took another break of two weeks and made it through 5km without major symptoms but could feel it afterwards. That was last week - thinking of trying again this week. I have no problems while cycling or during day to day activities just when running. I'm normally able to Handle vertical distance quite well and previously ran Ultras with loads of altitude.
Any tips on how to best deal with this? I do stability and core work 2 - 3 times a week, any exercises that I should add?
Can't deal with not being able to run. Pools are all closed and it's still to cold to cycle outside. Also not enough snow to replace the run with skimo.
Thanks!
Thanks!
