With running, Vdot is often used to find paces and can in ways be used to see your current ceiling. With running there are other factors also affecting this, where efficiency is the largest.
Now I was trying to see if there was any similar correlation made with cycling and Vo2max considering that this effectively only depends on power and doesn't rely on efficiency, in my head this would make the correlation stronger.
I remember reading here somewhere that most people if trained properly can get to 3.9w/kg. It would be interesting to see what the limit would be for someone with a vo2max of 60,65,70 etc.
Has anyone done any serious studies on this or has any data available?
Terrible Tuesday’s Triathlon
