I don't mean the 'if you have this rim and want to be that aero then it needs to be 103 psi' discussions that often happen on here. Just general rules of thumb based on the rolling resistance that will be created.
'old school' - fastest - pump the tyre up as hard as is reasonable - i.e. what the manufacture says it can take and level of discomfort you can withstand based on the road surface.
'new school' - fastest - now it seems that as hard as possible is not better (faster) and that something a bit lower - say around 90-95psi is most likely better. Ideally on a slightly wider tyre, perhaps a 25mm.
1. So is it the case that you don't need to pump the tyre up super hard (100+ maybe 110psi) for the faster performance but 90-95psi will do it? Even if it 'feels' slower?
2. How much is this road surface dependent If you have a. crap (bouncing all over the place) b. average ( roughish surface, the odd pothole), c. silky smooth tarmac? If it is silky smooth would you go to 100+ but only go lower because most road surfaces are average?
TIA.
TIA.
