joroshiba wrote:
spearit wrote:
About disk costs--I see disks on ebay used for less than $500.
I love my Zipp disks and ride em eveyday on my Zipp 2001 and 3001
Hope this helps
I got my disc for free, it isn't very true and the guy who had it didn't think he could sell it so I took it off his hands. I just loosen up the brakes a bit and go. Not like I'm really wanting to stop... plus the rear brake isn't all that powerful anyways.
That said as mentioned before if winds are greater than 15mph-20 mph depending on how long the race is and how fast it is I leave it home... simply because the yaw angle. You get a lot of side force and I'm really light I get pummeled in winds like that with 30mm rims, don't need to have the disc creating more side force (sail anybody?). It's not so much that I can't keep a straight line as my whole bike gets pushed to sharp enough angles to the ground that I physically need to stutter my pedaling to "push" the bike veritcal again. That's counter productive. For the majority of users probably fine.... but I'm 52kg @ race weight. Running a deep rear works alright in such scenerios, still not the easiest, but doable.
Just curious, but what front wheel (and depth) are you running when that happens?
Personally, I'll reduce the depth of the front wheel until it's a low profile rim before I'll go away from a disc in the back.
The reason that adding surface area to the rear typically helps to stabilize a bike is that the tilting of the bike away from the wind caused by the additional surface area helps to counteract the turning
into the wind caused by the torque on the front wheel (due to the surface area center being in front of the steering axis) and the "countersteering effect".
Have you ever ridden around with a deep front wheel and a shallow rear? In even light winds, the steering is very "squirrelly". Then throw a disc on the back of the bike and "Voila!", everything settles down.
