Andrew Coggan wrote:
A model can said to be "broken" when it predicts something completely nonsensical, e.g., when W' balance goes negative. That's not the case with the data above, as you are merely comparing the measured and predicted data.
I should also point out that 1) the two estimates of FTP (i.e., mFTP and 60 min power agree exactly), and 2) TTE isn't predicted with the same precision as the other model parameters - indeed, it can't be, due to the shallow slope if the power-duration relationship in that region (such that, e.g., even a 1 W difference in power translates into a much larger difference in duration). Recognizing that obvious fact (which I have pointed out ever since TTE started being reported), the difference between 45 and 60 min (which seems to be what caught your attention) is practically irrelevant.
IOW, you are making a mountain out of a molehill (just like Trev the Troll).
If you feed the WKO4 model a valid MMP60 data point and it spits out that TTE is 45min @ mFTP of 234w then your model (and determination method for TTE) is broken. The fact that the mFTP and MMP are equal is just luck and you know that is a very very very deceptive argument. If you know as much as you claim to do then you should be ashamed for saying that.
You might want to review the annotated graph below showing how poor the WKO4 model does at fitting the data. Why is there a 12w gap at the 60m when the MMP data from 40-60m is so flat? Model error. Sure if you feed it more data it will get better, but if the model can't get the 40-60minute domain correct after feeding it a good 60MMP data point then it has issues.
