BigBoyND wrote:
Hey Vision, this bar looks great! I love that the basebar can be flipped and that there is a center-pull cable exit.
I have a couple questions/requests:
1. Would/will you consider making a clamp kit like TriRig's "slammed clamps" to align the extensions with the basebar like your old TFA bar? I'm currently on a 58cm P5-3 with Ventus II bar as long (120mm effective stem) and low as it goes: no steer tube or pad spacers, ~65mm stack from aerobar. I'd like to try getting lower without giving up adjustability for future fit/frame changes.
2. Is your bar fully compatible with the P5 and SuperSlice? By "fully" I'm wondering whether the front brake cable clears for center-pull exit and rear brake can be routed out the back of the stem. SuperSlice seems to be one of a few frames that is lower and longer than my P5.
Thanks!
BigBoyND, sorry for the delay in response. We took some time to be as thorough as we could.
The “slammed arm rest plates with the extensions under the base bar” position was something we heavily considered during the design phases for the Metron. In the end the added cost/weight and limited adjustability of the additional configurations for the arm rest plates in those low stack positions would have pushed the project out of the target goals we had set. That isn’t to say we are giving up on this idea for the future, just that for this version we could not find a workable solution to what you propose.
P5:
The Metron aero bar is fully compatible with installing on your P53 and should be no issue. The key point is that you have enough steer tube exposed from the top cap of the headset (29mm minimum is needed) to clamp the Metron aerobar on the fork. As for the cable routing the Metron aerobar has many options for routing the front/rear cable paths with exhaust ports coming out the back and underside of the bar/stem. Your bike, you choose.
Super Slice Disc TT;
The feasibility to change out Cannondale’s integrated bar would have to be worked out with the dealer and depending on how cannondale sells them from the factory might be a hassle for both parties.
Can it be done? Sure, but there are a few hoops one would have to jump through with a dealer to change it out and make it possible.
Back to that minimum 29mm steer tube clamp surface…You will need a uncut fork-steer tube from the factory. (This is assuming the SS forks are pre-cut for each size and they ship as is.) The SS integrated stem has a shallow height clamp (27.5mm) with a minimum surface of 26.5mm needed on their 1-1/8th steer tube. Now 2.5mm of steer clamp surface area might not sound like a lot to some, but to us that is the difference between having a secure component or making a unexpected trip to the ER. So IF (this is a big IF) one could get a new uncut fork from Cannondale for the Super Slice from the factory, the dealer/mechanic could then cut the steer tube properly to fit the Metron Aerobar and it could work. The Metron stem steering clearance is within the same dimensions as Cannondale’s so you would have no rotating interference with the integrated cable fairing that is mounted between the stem and top tube.
The second hoop involves the integrated cable fairing that routes the cables at the back of the stem into the Top tube. Considering the Metron Stem cable exhaust ports will be 3mm taller in stack than Cannondale’s, this cover could possibly need a slight modification (or removed) to ensure good cable flow from the stem into the frame. All said, we have to state that any modification to the frame or frame components could also void any warranty with Cannondale.
So to conclude; if you are thinking about buying a Super Slice TT, please call and or talk to your local Cannondale dealer before purchasing about any changes you would like to do (and if they are possible) before going down that rabbit hole.
Thanks for the interest, hope this helps!
