grumpier.mike wrote:
I watched the video of the new aerobars. The one missing component seems to be the ability to move the elbows closer together. It would be great if you could add an adapter plate so that the pads could be moved close enough to touch. Narrow is aeroGrumpier Mike, If you favor a “Narrow is Aero” arm rest position we got you covered….and more importantly no adapter plates are needed! The Metron aerobar arm rest plates are a Asymmetric flip-flop design which can be orientated in 4 different positions to meet a wide range in width and reach. Though the minimum width called out in the spec is 111mm Center to Center (210mm Outside to outside), it is possible for the user to go to an absolute minimum arm rest measurement as low as 96mm Center to Center (195mm outside to outside). In this narrow position there is literally a 2mm of overlap with the arm rest plates but since the plates are composite, the small amount of flex they have at the ends will compress together and work.
For those curious about widths on the other end of the spectrum, the width positions step outward every 15mm to the max which is 261mm Center to center (360 outside to outside).
Please see attached diagrams below.
Vision-USA: Jul 25, 18 14:41
