Tom_hampton wrote:
My staple mainsets is: 30x100 on 20s rest.
Choose a pace that you can do around 10-12 in a row. Maybe your current 1000 tt pace minus 2-4 seconds.
Do as many as you can at that pace. When you miss the pace (I use a 2 second buffer), rest for a complete interval. Then start again. Do as many more as you can holding the pace. When you fail again. Rest another. Go once more until you can't hold the pace.
Alternatively, if after resting you immediately cant hold the pace... The workout is over.
I tend to keep going to complete the entire 30 reps...on the interval, but I drop the pace by 10s or so and end up with 10s rest.
Typically your first time you will fail around #12 or so, then maybe #17, and 20-22.
After that your goal the next time is to exceed those failures. Maybe #14, #20, #24. Etc.
When you can do 20 without failure... Drop the target pace by 2s, and start the process over.
I found doing this set 2x per week works well. Maybe 3x after you adjust for a few weeks. Add in a couple easy days to just stay in touch with the water.
ETA: I find it takes 2-3 reps to dial in the effort and pace. So I give myself some leeway on the target pace during the first 5 until I get dialed in. Usually #1 is a bit fast, #2 a bit slow, #3 about right.... Maybe slow on #4, and by number 5 I'm solid. Then you just keep it going until you blow up. :D it's great fun.
RBR, this is the set. As I'm a lot more experienced and much farther down the progression curve than Tom, I was a lot more strict on the failure criteria, though. I agree with giving yourself 5 reps to dial in. After that, I'd only allow myself 0.4 seconds buffer over target time. And if I missed consecutively, even if both were under 0.4 seconds slow, I'd call it a failure. (I use a finger stopwatch to time my repetitions to .01 precision). Exceptions were made if I knew the failure was a technical glitch (like a blown turn, accidental water ingestion, etc) and not neuromuscular failure.
I would recommend starting at your 1000TT pace + 1 second/100. If you fail to make it to ten for a couple workouts in a row, back off the pace. As soon as you make 26 or more before failing out, advance the pace for subsequent training, by at least a half a second/100, or maybe a second/100.
I did this, or something similar (75's, 125's, 150's) once or twice a week for 7 months. On the other days, I did similar sets of 25's at 100 free race pace or I did butterfly work.
