Pieman wrote:
I finished a 90 minute ride outdoors the other night, and my Wahoo Elemnt had NP as 217 watts, kj at 916 and calories at 916. Does that mean that my PM and Wahoo are inaccurate also? I was nowhere close to averaging 250 watts, but I did climb about 1300 feet during the ride.
DO NOT look at normalized power if you want to know energy burned during a ride.
- The kilojoules of energy put to the road is average power x time
- The kilojoules you consumed are essentially 4 x average power x time
- To convert to calories, roughly divide that by four so you are back to average power x time
If your kilojoules were 916 in 90 minutes then your average power
= 916 x 1000/(90 x 60) = 169.6W
NP is a fictitious construct when it comes to physics that roughly tries to convert the variability of your ride into some type of physiological equivalent wattage had your ridden the entire ride pegged at that average power.
To help simplify this, let's say I do 100 kilo bench press 4x 10 reps. According to this I moved 100 kilo x 40 x 0.5m (let's say 50cm is length of my arms) x 9.8m/s**2
The total work here is 19,600 joules
I could also do 20 kilos x 10 sets of 20 reps.
The total work here is 19,600 joules too,
Let's say I spread both efforts over 10 minutes (600 seconds) taking whatever rest I want between sets. Then my average power would 19,600 joules/600 seconds = 32.6 W
As far as physics goes I did the exact same amount of work and use the exact same average power over 10 minutes. It is just how I spaced all that out. Or I could do a single set of 100 kilos 40 reps of I could do 400 kilos x 10 reps
But for me if I did 40 reps of 100 kilos versus 200 reps of 20 kilos I will later feel a lot worse on the set with heavier weights but less often and more coasting/rest in between.
I don't know how you would calculate the NP for the 10x400 kilos set vs vs the 4x10x100kilos set vs the 20x10x20 kilos set, but from first to last the NP would go down.
NP goes up when you concentrate your workload into shorter higher power periods relative to a perfectly evenly spread out effort (ideally in an Ironman AP = NP). If you ever do a really steep hill climb that is 30 minutes of longer you will see your NP and AP will also be identical (your body will self select a sustainable even pace)
