desert dude is a wind tunnel guy where you test yaw as well. don't get that on the track where you see hands high do really well. high speed low side wind, hands high good. big side wind, probably not so much.
From that perspective, something I've been thinking about is these new style extensions that support your whole forearm don't allow for a lot of in-ride adjustment. With regular extensions I could put my hands on top of the ends of the extensions (in a hands stacked position) for low yaw situations, but then grab each extension and rotate my grip outward to where my hands were basically below the extension in high yaw situations. This also worked as you need a better grip on the extensions in high side winds.
