The B tension spring appears to be allowing travel in both directions, pretty easily. Do these wear out? Are they sold separately somewhere? Any info helpuful!
Is
this compatible? Or must it be
dura-ace? Results of my investigation:
I can install as pictured on page 30, no prob.
When I adjust B screw as pictured on page 64, nothing happens, because....
As pictured and discussed on page 93, I DON'T even have to use a 3mm hexagon wrench to get the claw on the stopper plate to cross the claw on the bracket body. I can do it with my hands/fingers. It's not tension-free, and it is challenging with fingers, but definitely no 3mm hex wrench needed. This makes me think the spring is worn out or loosened. I've uninstalled and reinstalled twice to ensure that I'm doing it in the correct orientation.
Visual inspection of spring looks fine. Only thing to note is that the springs ends (y) and (z) (Page 93) appear exactly opposite each other when the spring is unloaded, which is not the case in the Diagram 1 on page 93.
Global question for my understanding. At what point
should that spring allow disengagement of the claw on the stopper plate from the claw on the bracket body, during normal bike operation?
That claw interface is what appears to communicate the B screw "limit" at all times, on my wife's bike. As in, the derailleur can't go past (closer to cogs) than the limit screw at any time. Hard stop.
On my bike, there is no hard stop at all. It floats right past what should be the stop, though there is a tactile "stop" there, but the aforementioned "claws" don't stay engaged.
FYI: A year ago, probably when the derailleur started functioning as it does now (apparently improperly but good enough to ride for a year without much concern), I had crashed by sliding out on the right side of the bike so the derailleur took an upward-directed hit from the ground, which seems to have eliminated that "hard stop" and allows it to swing past the B limit, closer to the cogs.
Biggest question: is the RD issue likely to cause chain pop-off? I guess maybe yes... especially if paired with worn rings. And probably-worn bearings... I'll check those out when I install the new Ultegra crankset.
Dr. Alex Harrison | Founder & CEO | Sport Physiology & Performance PhD
📱 Check out our app →
Saturday: Pro Fuel & Hydration, a performance nutrition coach in your pocket.
Join us on YouTube →
Saturday Morning | Ride & Run Faster and our growing
Saturday User Hub
