Trisumai wrote:
I installed my Calpac and the thing is awesome. There is a magnet that comes with the fuelselage that allows the tubing to be secured in place along the aerobar so it doesn't go flopping about. I'll post a pic when I can.
One problem that I've run into is that it is a bit harder to fill the fuelselage while biking. Because the Fuelselage wasn't designed for the Felt and, as such, doesn't open up completely in the downtube, it results in fluid not filling the reservoir quickly and overflowing. I've put in another camelback tubing to create a channel for the fluid to go down which helps some however it still takes a little while to put the 16 oz into the fuelselage. Has anyone figured out a better solution? I think the ideal way would be to have some brackets that would create a scaffolding to keep the bag open but I have no idea how to do so.
Thanks for the feedback! I've had this issue, but solved it with getting the Fuelselage to sit better in the frame. What works for me when this happens: when you've put the Fuelselage in, try pushing the drinking tube a bit further into the frame as well. On my bike, this slightly pushes the Fuelselage further down and creates a nice opening in the 'neck' that allows fluid to fall down rapidly. Remind me, what size frame do you have, and which Calpac adapter did you get (small or large)?
Meanwhile, I've been using it happily for quite some rides. Did my first-ever race last weekend (IM70.3 Luxembourg) and it didn't let me down. Aid stations on the bike leg were quite short, so I had little time to grab 2 bottles and use 1 to refill the Fuelselage before the trash-zone at the end of the station, but I managed well! When you're in such a hurry there's some spillage, but I don't care, especially not on race day.
Felt IA Calpac mods on Shapeways:
800ml Specialized Fuelselage (XS/S) 1000ml Specialized Fuelselage (M/L/XL) DIY cover
