exxxviii wrote:
To amplify this post... When folks talk about slower or faster, they tend to focus solely on the caliper and disk but ignore the total system. We are at the early stages of holistic aero & speed design around disk brakes, so the future will only get brighter.
Almost all bike design R&D is focusing on disc brakes. Therefore, it is unlikely that any future rim brake bike will be faster than its disc counterparts.
When you eliminate the design restrictions of a rim brake, it does some major things to bike design that can improve both aerodynamics and rolling resistance:
- Bikes can accommodate wider tires without aero penalties
- Bikes can have wider forks and chainstays for aero benefits
- Wheels can be wider to integrate better with wider tires
- Wheels can have different shapes, optimized for aero right up to the edge of the bead
- All-carbon wheels can be lighter since you don't need a brake track
- Frames are stiffer thanks to thru-axle (not purely a disc thing, but pretty much driven by disc)
Caveat: both my bikes are rim brakes, and I have no immediate plans to upgrade. I would really love some of the benefits, especially on my road bike, but they are both great performers and I do not feel like the expense and maintenance transition right now.
Your list of points is the same one that usually comes up. But those points are either independent of rim vs disc brakes or not a net-benefit if you look at the system level, as you suggest.
- disc brakes have inherently greater aero penalty due to all the mandatory parts that stick into the wind, so that point doesn't work. Rim brakes can be made larger (see any old bike that isn't a pure road bike) and still come out ahead in aero
- same point as above. can make larger calipers or integrate them into the fork as all superbikes were doing, for no additional drag
- same as precious point
- purely theoretical. Think about this one for a second. How different from parallel are disc brake rims near the tire? Not much, if at all. AND rim brake wheels like SES 7.8 were already anything but flat up to the rim edge. The brake tracks were both angled and convex. Any shape you come up with can still be used with rim brakes. Show me one example of a disc wheel where this wouldn't work.
- disc brake rims being 10-20g lighter doesn't help much when you now need to add a 100g rotor, extra spokes, extra carbon at the caliper mounting point, etc. Disc will always be heavier as a system.
- thru axles are an independent design decisions. Rim brake frames and wheels can be made with thru axles if that's a better solution than skewers.
