Any tips on installing this easily? I'm finding it fiddly as hell!
It's the two thread parts that go inside the extensions which need aligned with the bolts that come underneath up from the base bars, and down from the arm rests that I'm finding a nuisance. With much faff I've managed to attach the extensions to the base bar. Great. But now I can't get the arm rests on as I can't get the thread parts lined up and held secure for the bolts to find purchase.
I notice the thread parts are also threaded on both ends. I'm guessing that there is some tool or bolt that will screw into it and make this a lot easier that trying to use your fingers!
I'm dreading repeating this whole process over and over to get them dialled in.
Also, the bolts are really short. The longest bolts definitely can't support the rather measly risers supplied in the kit if you max them out. Thinking I need to buy a riser kit which has +5cm and looks like it has long bolts. But that's about £90 here in the UK. Shocking!
