"even in 'rear position' the p2 has a more forward seat tube than the soloist. "
So why would you want a more forward seat tube in a road bike configuration? This makes little sense if you're using the P2K/P3 as a road bike in road racing, climbing or group riding. The Soloist will be a better bike for this. Much better balanced since this is what it's designed for.
Also have a look on the Cervelo website for the geometries. For example a 54 cm P2K/P3 frame has a 12 cm head tube but a 54 cm Soloist has a 14 cm head tube. So for a normal saddle to bar drop difference in a typical road bike position, you'll have to use 2 cm of spacers on the P2K/P3 not necessary with a Soloist.
If you're using the P2K/P3 in a steep position with drop bars this makes even less sense. The reach to the drop bars is much greater assuming you're riding low in the front and becomes very awkward unless you've got unusual flexibility. That's why the base bars for tri bikes are flat rather than slanted down.
There are problems trying to convert a road bike to a tri bike, but they're even worse trying to convert a tri bike into a road bike. It's doable but not optimal in either case.
Read Slowman's article about seat angle and bar drop.
http://www.slowtwitch.com/...techctr/basebar.html
