I'm considering buying some HED3's that are .035" out of true. Will I notice?
Marcel
You already did.
Tom Demerly
The Tri Shop.com
our spec is .025 and we try to keep it much tighter than that. We get wheels back from angry customers all the time that are " waaaay out of true". When we check them with a dial indicator they are usually on the high side of the spec. I just found a wheel out back that was .030 out. I would consider it pretty bad and I wouldnt want it on my bike. The flip side of that is the HED 3 is a tt wheel and you can run your pads pretty open in a tt(not much braking required). If your frame is tight though it might pose a problem.
Well crafted...but obviously not what I meant.
Marcel
