In Reply To:
I'd like to know who stillman is and how he came up with that scale. According to those calculations I should be 181 pounds for my height, which is laughable considering my weight is generally 205 and my body fat is pretty damn low. Maybe he's talking about people who have never stepped foot in a gym to lift weights?
Here is a portion of an article I read on the subject at
http://www.serpentine.org.uk/advice/coach/fh01.php: [/url]G
etting it right: weight relative to height in distance running by
Frank Horwill Most coaches use the Stillman height/weight ratio table for distance runners. The average man is allocated 110 lbs (50kg) for the first 5 feet (1.524m) in height. Thereafter, he is allocated 5˝ lbs (2.495 kg) for every additional inch (O.025m) in height.
Thus, a man 6 feet tall (1.829m) would be allocated 110lbs (50kg) plus 12 x 5˝lbs (2.495kg), which comes to 176 lbs or 12 st 8lbs (80kg). The exceptions to the rule are Japanese wrestlers, heavyweight boxers and certain rugby players, who aim to exceed this weight. Females are allocated 100 lbs (45kg) for the first 5 feet (1.524m) and 5lbs (2.268kg) for every inch thereafter. Therefore a woman who is 5 ft 6ins (1.676m) tall would be given 100 lbs plus 6 x 5lbs, which totals 130 lbs or 9st.4lbs (59kg).
These allocations are considered healthy guidelines for non-active people. However,
a distance runner needs to weigh less, about 5 to 10 per cent less. This makes our 6 foot tall male requiring to be 8 to 17 lbs
less than his 1761bs, around 168lbs to 159 lbs. And our female of 5ft 6ins should be around 6 lbs to 13lbs
less, around 124 lbs to 117 lbs.
The key factor in successful distance running is your height : weight ratio. ______________________________________
Now, because triathletes need more upper body mass than a distance runner, you probably don't need to be 10% less, but those figures take into account muscle, etc. 5' 8" and 220 isn't healthy if it's fat or muscle. Your frame was not meant to carry that much weight, period.
Dave in WI
"What you once were isn't what you want to be anymore" - Wilco
