Tom A. wrote:
Slowman wrote:
i don't suffer from the lack of that underlying data you ask for. i don't feel i need that data to understand what zipp is trying to express with these graphs. however, i respect your view and honor your background in this, so i don't mean to minimize your desire to see the data not supplied.
as to the rolling road, i might misremember but i think this is the second time "lack of transparency" has been used as a descriptor in this thread and, again, unless i misremember you've been the user both times. to me, this connotes and intentional act to withhold data. i gave you the protocol. rider aboard, 85 kilos rider + bike, roll up to speed for 30sec, the test runs for 90sec, rider dismounts. there were 96 total runs. there were 24 set ups tested (a given wheel with a given tire width at a given pressure). to me, dividing 96 by 24, that means they performed 4 runs per set up. zipp says the rolling road is a "standard" to use their word road surface, analogous to their eagle creek field testing circuit.
if what you want is a picture of the rolling road, i'm pretty sure one could be provided. do you want the speed of the rolling road? the speed of each test? i'll ask. but i don't see the lack of transparency you see. perhaps you could tell me what it is you don't see and i'll see if i can get it for you. just, if you're going to ask for data beyond that which is typically given by drum testers, such as you or al or BRR, then i have to cry foul. sauce for the goose and all that.
Yes, I recall your description of the number of runs above...but, what's missing is some sort of description of the equipment used and how the method was "validated". Here's a short list of things off the top of my head that could be helpful:
- How was power measured? What's the accuracy and precision of the equipment? Is the power measurement inclusive of drivetrain losses? If not, how is that handled (i.e. is gear selection fixed? Something else?)
- How well does the method detect a "known" change in Crr (i.e. the "Tom Compton Challenge"), such as what happens when mass is added to the setup? Does the Crr change in the expected way? What's the smallest change detectable reliably?
- What's the surface roughness which the test setup is attempting to duplicate? How well does it mimic that "specification"? (This is where the PSD data referenced earlier would come in handy to evaluate how well the test setup duplicates the intended surface).
- Was the same rider and bike used for all tests? If not, how do we know their "damping" is similar (for pressures above breakpoint)?
- How does the data compare (numerically) to what is found using simple roller tests and field tests? If it differs, then how...and what are the possible sources of the differences?
- How tightly is ambient temperature controlled in the test location? If it's not, is the temperature compensated for in the results (due to the somewhat important temperature effects of Crr)?
I believe all of the above have been reported and investigated for both roller and field test methodologies. I understand the desire of the Zipp Engineers to use their "rolling road" as a proxy for field testing. It eliminates translational aero drag AND puts to rest any arguments against validity from people who don't understand the "equivalence" of rollers to flat surfaces...in other words, it's slightly more "real world" for some consumers. That said, it is going to have it's own quirks, and being able to understand those quirks is the way we can put their results in context. It's just like understanding that roller testing (when done carefully) is extremely good for evaluating tire hysteresis properties (and thus Crr) for pressures below the "breakpoint" of the system. Again, it's all about context.
edit: I thought of one more (very important IMHO) piece of info on the treadmill:
- What is the thickness and material of the moving belt, and how is it supported? How does that compare to an actual road surface in terms of compliance and damping?
i'm not going to bother zipp with this. i'm just going to answer it and if i'm wrong zipp can correct me when they read it.
the power was measured using a quarq power meter on the bike of the sole person on the only bike used for all 96 runs. accuracy? it's the accuracy of a quarq power meter. there's at least a half-dozen ways i can think of, off top of my head, for dropping the 90-second captures into data analysis. gear selection was fixed, because speed was constant for all runs. drivetrain losses are not material to because the actual power is not relevant (who cares how much power it takes a given rider to ride his bike at 20mph on a rolling road?) the only thing that's relevant is the delta in power between the set-ups.
the surface roughness has been asked and answered at least 3 times in this thread. what is relevant, that i don't know - also mentioned at some length in this thread - is the vibration in the entire system which could - just using my intuition - add to the "roughness" of the road. i think this is worth investigating.
was the same rider used for all the tests? yes. as i pointed out in posts twice above. how does the data differ from field tests? the data, per zipp, syncs well with their fields tests, which they perform at eagle creek park, on a circuit, and which i stated at least twice, both in this thread and i believe in the article on the front page.
how tightly is the ambient temp controlled in the test location? again, just my intuition, but in the 25,000 square foot factory where i built my bikes i hit on the idea of setting the thermostat on my HVAC. this has not been mentioned, explicitly, so for those who have this question: zipp's rolling road is inside its building, not outside.
Dan Empfield
aka Slowman
