In Reply To:
In Reply To:
All we need are the top and low speed numbers for the speed variation
Okay, here you go - but first, a reminder re. the starting assumptions:
CdA: 0.300 m^2
Crr: 0.0045
Total mass: 85 kg
Efficiency of drivetrain: 97.5%
Air density: 1.185 g/L
Power @ 600 W for 0.5 s, then @ 0 W for 0.5 s (equivalent to pedaling at 30 rpm for those too dense to figure this out for themselves <g>)
Speed at t = 0 s: 11.1378 m/s
Kinetic energy at t = 0 s: 5272.15 J
Speed at t = 0.5 s: 11.2908 m/s
Kinetic energy at t = 0.5 s: 5417.96 J
Change in kinetic energy: +145.81 J
Speed at t = 1.0 s: 11.1378 m/s
Kinetic energy at t = 1.0 s: 5272.15 J
Change in kinetic energy: -145.81 J
Note that the average speed (which equals 11.2090 m/s) is less than the average of the minimal and maximal speeds, as the rates of acceleration/deceleration are not linear...
Here is another way to look at this. How much work does it take to accelerate an 85 lb object from 11.1378 m/s to 11.2908 m/s in 0.5 seconds.
The acceleration 0.153 m/s in 0.5 seconds or 0.306m/s/s. This requires a force for the 85 kg object of 26.01 N
Work is force through a distance. If the average speed is 11.2 m/s this means the object is acted upon for 5.6 meters with a force of 26.01N resulting in 145.6 joules of work being done just to accelerate the object. Pretty good agreement.
But, we are putting in 150 joules. If there were no air resistance we would expect to put an extra 150 joules of energy into the system and see an extra 150 joules added to the KE. But, instead we only see 146. That means to me the variation is costing 4 joules due to the non-linear aspect of the resistance, or 4 watts, at a frequency of 1/sec,
This gets us back to the same number we had many pages ago on this thread, post 98. a loss of about 4 watts out of 300. In retrospect, that number was correct because it looked at the average speed cost using the work/energy principle. That, I believe, was the "easy" correct solution to the problem.
So, it gets us back to arguing whether 4 watts is insignificant or not. I submit it is "small" but not insignificant such that there is potentially more to be gained by changing pedaling pattern than by, say, getting a lighter bicycle. The "cost" be smaller for more normal pedaling patterns but, again, how small does something have to be to be "insignificant"?
Frank,
An original Ironman and the Inventor of PowerCranks
