Bottom line I need a headset for a diamondback Haanjo
1.5 - 1-1/8 tapered fork.
Upper frame measures 42mm inner diameter
Lower frame measures 52mm inner diameter
It came with bearing cups pressed in and I tossed them.
the manual said it uses an FSA c40 headset (standard integrated type headset). So i took my old headset out and also push the bearing cups out as well. As the headset that came with the bike had bearing cups pressed into the frame then a separate race.
Now I was left with a just a frame and thought these bearing would fit. They don’t. They measure about .2mm to small and create lots of play.
I’ve called diamondback and FSA and neither can tell me what I need. Diamondback says their books say c40 but know it’s incorrect.
Any help is appreciated.
